1997 Chevy Astro
DENTRIX01
  • 1997 CHEVROLET ASTRO
1997 Chevy Astro Two Wheel Drive Automatic
How do I change brake pads? Thanks
Tuesday, March 16th, 2010 AT 6:46 PM
TOOOMANYTOYS
  • 513 POSTS
Just the front pads? Remove the front wheels. You need an allen wrench set. Reove the two allen head bolts from the caliper. Slide the caliper off the rotor. Remove the outside pad. Use a caliper piston depressor or a c clamp to push caliper piston all the way in. Installed new pads add antiseize lube to all moving components except on friction surface of pads and rotor. Install caliper and tighten allen bolts. Install wheel and make sure you pump the brake pedal before driving.
Tuesday, March 16th, 2010 AT 7:18 PM
