1997 Chevy Astro
HALE2004
  • 1997 CHEVROLET ASTRO
Engine Cooling problem
1997 Chevy Astro Two Wheel Drive Automatic
my van seems to not have antifreeze and is overheating. What could be some causes of this?
Friday, May 15th, 2009 AT 1:00 PM
  • 109,885 POSTS
First, do not drive it without coolant. When you refill the coolant, MAKE SURE TO USE THE CORRECT TYPE. Some of the vans use Dexcool coolant and it CAN NOT be mixed with other types.
Next, Once the coolant is refilled, keep an eye on where there is a leak coming from. It could be many things, radiator, water pump, radiator hose, head gasket, intake gasket, freeze plug.
Let me know what area it is coming from, front, rear, sides.
Monday, June 1st, 2009 AT 10:09 AM
