1996 Chevy Astro Ventilation seems stuck on defrost.
138,000 MILES • 6 CYL • 2WD • AUTOMATIC
FNICELY
The air on my van will only blow through the defrost vents on top of the dash. The a/c works but only blows through the defrost vents. Its like there is a damper or diverter gate that is stuck sending the air only to the defrost vents. Does anyone know how to repair this?
Sep 18, 2008 at 10:05 AM
MERLIN2021
  • 17,250 POSTS
You have a vacuum leak in the supply line from the reserve tank. Or the tank leaks. Look at #'s 2 & 3...
https://images.2carpros.com/forum/automotive_pictures/62217_vac_1.jpg
Sep 18, 2008 at 10:23 AM
FNICELY
Merlin, you were right. I found a vacuum line broken in two. I repaired it and now I have air coming through my dash vents. Thanks for the tip. You are a real gem.
Sep 18, 2008 at 11:15 AM
MERLIN2021
  • 17,250 POSTS
Glad to help!
Sep 19, 2008 at 7:27 AM
