1996 Chevy Astro speedometer
104,000 MILES • 6 CYL • 2WD • AUTOMATIC
RACERX01
all my gauges are working except my speedometer and my gas gauge. i cannot find a relay or a fuse to see if i have blown it or not. also i installed a new radio and it quit working also. so what do i do. where do i check for these fuses and relays.
Oct 19, 2008 at 4:50 PM
DAVE H
  • 13,383 POSTS
the speedometer is controlled by the VSS (vehicle speed sensor) there must be a circuit fault somewhere ? disconnect fuel tank sender unit elec connector .. turn on ignition(not start vehicle) if gauge indicates full .. replace sender unit ... if guage indicates empty .. there is a fault at the instrument cluster .. either faulty gauge or gauge grounded in some way ..
https://images.2carpros.com/forum/automotive_pictures/266999_Graphic6_1.jpg
https://images.2carpros.com/forum/automotive_pictures/266999_Graphic7_1.jpg
https://images.2carpros.com/forum/automotive_pictures/266999_Graphic8_1.jpg
The underhood fuse/relay box is behind the battery ..
Nov 9, 2008 at 3:25 AM
