1996 Chevy Astro Radiator
1996 CHEVROLET ASTRO
147,000 MILES • 6 CYL • 2WD • AUTOMATIC
NICK THE CAR GUY
My vehicle overheated yesterday, and after letting it cool down, adding some water, I was able to llimp home safely. While my van was starting to overheat, I noticed the temp guage would rise only while the van was sitting at a traffic light. So, the next morning, after filling the radiator with water, I ran the vehicle while closely watching the temp guage. When I got back from my test drive, I popped the hood open, and felt different spots around the radiator. About 90% of the radiator felt cool to the touch, while the vehiicle was completely warmed up. I then added some radiator cleaner and some super flush in, ran the van another 12 miles or so,checked the radiator again, and about 2/3 of it was warm/hot to the touch. I ran the van another 9-10 miles in about 80'-90' temperatures, and the temp guage stayed between 190-210. My question is, would the rest of the radiator be cleared out,if I continue to run the super flush and radiator cleaner thru the system for another week or so? The price of a new radiator is $166, and I dont want to spend this if I dont have to. However, I dont want to burn up the engine, for NOT making the $166 investment for the radiator, that I would put in myself. I also know that radiators can be rodded out. Any suggestions or comments would be greatly appreicated.
Sep 11, 2010 at 10:19 PM
SATURNTECH9
  • 30,869 POSTS
Are both your upper and lower radiator hose's getting hot i would be looking at your thermostat if it isn't opening then your radiator won't get any hot coolant going thru it.Your engine would also over heat.
Sep 12, 2010 at 12:46 AM
SATURNTECH9
  • 30,869 POSTS
Nick the Car Guy said>Thanks for your response Louie.I replaced the thermostat with a new one 6 days ago,and both lower and upper hoses are hot to the touch. I had this same exact problem with a Hyundai Excel I had years a
saturntech9 said>If you just replaced the thermostat and both hose's are getting hot then i would make sure your thermal fan clutch is good.When it get's too hot is the fan blowing a lot of air like a hurricane you be able to really feel the air moving around.
Sep 12, 2010 at 12:32 PM
