1996 Chevy Astro outer front tire ware
18,900 MILES • 6 CYL • 2WD • AUTOMATIC
CURTISSJENSEN
I have had my alignment done several times. Still have outer front tire ware. Could this be due to the camber not being adjusted??
Apr 22, 2010 at 2:42 PM
HMAC300
  • 48,601 POSTS
if you have your truck alinged the camber should have been checked and adjusted if needed. Caster can also screw up tires. Or hard driving and fast cornering,especially on a van due to weight up front. Aslo have your front end checked for ball joint/idler arm/and trailing arm wear.
May 4, 2010 at 12:44 PM
