1996 Chevy Astro No Spark
159,000 MILES • 6 CYL • 2WD • AUTOMATIC
HEHONGEL
At the coil there is 12 volts but no spark coming out of the coil wire. Replaced the coil still same problem, replaced the distributor with new; still same problem. Could it be the PCM? or something else? Is there a way to test the PCM if so how
Apr 13, 2009 at 2:01 PM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Apr 13, 2009 at 2:19 PM
