1996 Chevy Astro KEYLESS ENTRY
259,000 MILES • 6 CYL • AWD • AUTOMATIC
WILLGOOD2
MY KEYLESS ENTRY DOES NOT ALL WAYS WORK ? I HAVE CHECKED THE REMOTES AND THEY ARE WORKING FINE. THIS IS THE SAME FOR BOTH REMOTES I HAVE SOME TIMES THEY WORK MOST OF THE TIME THEY DO NOT?
Sep 11, 2010 at 2:14 PM
WILLIAM_STELTER
  • 24 POSTS
Usually a antenna problem. You can try looking up serial number with you keyless entry company and see if they offer a replacement one. Or just move the placement of the antenna. If the antenna is placed to close to a power wire that can cause a issue.
Sep 23, 2010 at 10:04 AM
WILLGOOD2
SO WERE IS THE ATTENNA
Sep 23, 2010 at 12:46 PM
WILLIAM_STELTER
  • 24 POSTS
Usually a small piece of plastic with 3 wires attached. It all depends on your model. Another thing you can try is when you use your remote put it by your chin when you press it. I know it sounds stupid but it accualy boosts your remote antenna by 20-30% if you have a extended antenna it will look like the one in the picture below. other wise it will only be 1-2 inches long right off the box
https://images.2carpros.com/forum/automotive_pictures/575692_rs830n2_1.jpg
Sep 23, 2010 at 1:00 PM
