1996 Chevy Astro Gas smell
ETSANTAN
1996 Chevy Astro Automatic 135,55 miles
I just purchased a chevy astro van and it has a very bad gas smell in it. I tried to contact the seller (private) and he will not return my calls.
I have to drive with the windows open because the smell makes me cough.
Do you have ant suggestions?
Aug 29, 2009 at 6:18 PM
  • 75,988 POSTS
Running too rich could be caused by the following a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
Aug 29, 2009 at 6:51 PM
