1996 Chevy Astro engine stopped while driving
102,700 MILES • 6 CYL • AWD • AUTOMATIC
TDARNALL
I was comming home from work I herd a small thump like Iran over something the engine stalled I coasted to the side of the road,
When i got it hoe & started troubleshooting the problem it would start to turn over then cough like the exaust valve did not open, I checked fuel line , no problem , I started to remove the spark plug wires one at a time , When I removed #4 wire it started a little rough in running but i could move the van , I took off the valve cover expecting to see one of the rocker arms broken , all intact& moving just fine, y next thought is the spark plug or wire
am I on the right track??
Aug 25, 2010 at 1:42 PM
  • 75,988 POSTS
Check the fuel pressure with a fuel pressure gauge designed for your system to rule out the fuel pump
Aug 25, 2010 at 2:20 PM
