1996 Chevy Astro ENGINE LIGHT
181,000 MILES • 6 CYL • AWD • AUTOMATIC
WEEB32
MY ASTRO VAN THE CAM TIMING SENSOR AND CRANK TIMING SENSOR HAVE RECENTLY BEEN REPLACED BUT THE PROBLEM HAS NOT BEEN REMEDIED. THE ENGINE LIGHT COMES ON AND THE VAN SPUTTERS WHEN ACCELERATING AND ALSO AT IDLE, BUT WHEN THE LIGHT GOES OUT THE VAN WORKS GREAT. THE LIGHT TURNS ON AND OFF SPIRATICLY MANY TIMES THE LIGHT CAME ON AND I TRIED TO TAKE IT TO THE LOCAL GARAGE TO READ THE CODE BUT ON THE WAY THE LIGHT WENT OUT. ALSO OVER SHORT DISTANCES THE ENGINE IS RUNNING HOT WITH A SMELL OF RUBBER. IF YOU HAVE AN ANSWER FOR THE ABOVE I WOULD GREATLY ENTERTAIN.
Apr 28, 2008 at 11:23 AM
BMRFIXIT
  • 19,053 POSTS
codes will be stored in the memory and even if the light out
you still can get the codes
have it checked
Apr 28, 2008 at 11:44 AM
