1996 Chevy Astro ac vents
15,200 MILES • 6 CYL • AWD • AUTOMATIC
TODDYG
front ac blow from the defrost vent only it was working blowing from dash board vents, is there a lever that chance this problem?
Jul 21, 2010 at 11:37 AM
  • 110,248 POSTS
You have a vacuum leak. The air flow direction is done by vacuum actuated vent doors. If there is a loss of vacuum, it goes to the defroster. Check under the dash. If you are lucky, with the engine running, you may hear a hissing sound.
Let me know what you find.
Jul 21, 2010 at 4:26 PM
TODDYG
Ididn't hear any hissing any other remedy to my problem
Jul 23, 2010 at 2:25 AM
  • 110,248 POSTS
Honestly, I feel strongly that there is a leak. I was hoping you would hear a hissing to help locate the problem. If you don't, you have to start following the vacuum hoses to see if any are damaged or disconnected.
Jul 23, 2010 at 5:40 PM
TODDYG
you guys are the best! I found the broken hose, replaced it and the air works fine! In the process of replacing all hoses they become brittle in this Arizona heat thanks!!
Jul 24, 2010 at 2:10 AM
  • 110,248 POSTS
Arizona... I thought it was hot here in PA. Nearing 100 degrees with like 80% humidity. It's hard to breath outside. But that probably sounds like winter to you. I have always wanted to visit AZ. Maybe some day when my kids are grown I'll have a chance.
Good job finding the leak. They are a pain, but I knew that is what it was. Take care of yourself, tell your friends and family about the web site, and thanks for using 2carpros.com.
Jul 24, 2010 at 3:42 PM
