Front ac blow from the defrost vent only it was working blowing from dash board vents, is there a lever that chance this problem?
Wednesday, July 21st, 2010 AT 6:37 PM
MECHANIC
You have a vacuum leak. The air flow direction is done by vacuum actuated vent doors. If there is a loss of vacuum, it goes to the defroster. Check under the dash. If you are lucky, with the engine running, you may hear a hissing sound.
Let me know what you find.
Wednesday, July 21st, 2010 AT 11:26 PM
TODDYG
MEMBER
Ididn't hear any hissing any other remedy to my problem
Friday, July 23rd, 2010 AT 9:25 AM
MECHANIC
Honestly, I feel strongly that there is a leak. I was hoping you would hear a hissing to help locate the problem. If you don't, you have to start following the vacuum hoses to see if any are damaged or disconnected.
Saturday, July 24th, 2010 AT 12:40 AM
TODDYG
MEMBER
You guys are the best! I found the broken hose, replaced it and the air works fine! In the process of replacing all hoses they become brittle in this Arizona heat thanks!
Saturday, July 24th, 2010 AT 9:10 AM
MECHANIC
Arizona. I thought it was hot here in PA. Nearing 100 degrees with like 80% humidity. It's hard to breath outside. But that probably sounds like winter to you. I have always wanted to visit AZ. Maybe some day when my kids are grown I'll have a chance.
Good job finding the leak. They are a pain, but I knew that is what it was. Take care of yourself, tell your friends and family about the web site, and thanks for using 2carpros. Com.
