1996 Chevy Astro
10,000 MILES • 6 CYL • 2WD • AUTOMATIC
BABYBOYJRDADDY
it turn over but what start
Nov 21, 2008 at 1:57 AM
AUTOTECH04
  • 16 POSTS
do u have spark,or fuel pressure.
check for those things first.if u dont have fuel pressure or dont hear the pump prime when the key is turned on. check for power on the gray wire @ the fuel pump harness connector also check the ground.
if no spark @ the spark plug. check @ the cap & then @ the coil. if no spark @ the coil it might be a bad coil or coil module !!!!
Nov 21, 2008 at 1:31 PM
