do u have spark,or fuel pressure.
check for those things first.if u dont have fuel pressure or dont hear the pump prime when the key is turned on. check for power on the gray wire @ the fuel pump harness connector also check the ground.
if no spark @ the spark plug. check @ the cap & then @ the coil. if no spark @ the coil it might be a bad coil or coil module !!!!
Nov 21, 2008 at 1:31 PM
