1996 Chevy Astro
300,000 MILES • 6 CYL • 2WD • AUTOMATIC
KENNETH NOLEN
when i'm at a stop with my foot on the break pedal & press down on it a little harded and or turn the steering wheel a little bit the engine boggs down real bad like its going to die what could cause this to happen tried almost everything
Sep 20, 2009 at 2:34 PM
  • 110,251 POSTS
Has the check engine light come on? Have you checked fuel pump pressure?
Sep 22, 2009 at 6:50 AM
KENNETH NOLEN
[quote:263c80b38a="Jacobandnickolas"]Has the check engine light come on? Have you checked fuel pump pressure?[/quote:263c80b38a]no check light and the fuel pump was changed we are leaning on the power steering pump/brake booster?
Sep 24, 2009 at 12:07 PM
  • 110,251 POSTS
It could be a vacuum leak. Check the hose to the booster and vacuum test the brake booster.
Sep 24, 2009 at 12:16 PM
