1995 Chevy Astro valty wiriing problem or bad ground
JIMMYEDWRD
1995 Chevy Astro
My van radio AC and widows all stopped working at once for a couple minutes and then started working again.
Aug 19, 2010 at 4:37 AM
JDL
  • 16,098 POSTS
Intermittent issues can be hard to track. The circuits you named get ignition feed. Goes hot when you turn on the key. If the problem lasts long enough, check feed to and from the ignition switch.
Aug 20, 2010 at 4:04 AM
