1995 Chevy Astro stalling
105,221 MILES • 6 CYL • 2WD • AUTOMATIC
MIKE1122
Had a complete tune up. engine runs rough, sometimes stalls. it runs way better with the a/c on.
May 17, 2010 at 12:02 PM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following-inspect and test all the following below:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
May 17, 2010 at 3:42 PM
