1995 Chevy Astro shakes
1995 CHEVROLET ASTRO
153,550 MILES • 6 CYL • 2WD • AUTOMATIC
ASTRO95
I have a 1995 chevy astro van with 150,000+ miles. i just recently had tune up, brakes done, and alignment done to it with new tires. My problem started not to long ago. When I brake, there is a sound like grinding on right side brakes. It seem to do it at high speeds and is normal at low speeds. I had a new rotor put in on front right side. Could it be warped ? And another problem accorded. I was driving on the freeway and suddenly the van started to shake. And when I started to slow down it started to shake more. This happen at speeds 50-70 mph. the shaking stop when I drove under 50 mph. Is this have to do with the suspension ?
Apr 7, 2008 at 11:29 AM
RHALL77
  • 3,361 POSTS
i would have the tires check for out of balance. Sounds like a wheel weight may have come off. as for the shaking were all the brakes done or just front or rear?
Apr 7, 2008 at 12:46 PM
