How do you loosen/adjust the tensioning pulley on
this vehicle?|
Nov 2, 2008 at 12:32 PM
JDL
✓Experienced Mechanic
The picture is the courtesy of autozone. You can go to the site, click on (vehicle repair guides) follow the links. I believe the serpentine belt info is on the( maintenance link )page.
Usually the tension adjustment is automatic. In the picture, you just pull-up on the wrench to take tension off the belt.
