1995 Chevy Astro performance
165,000 MILES • 6 CYL • 2WD • AUTOMATIC
WESLEY_MYS
  • 10 POSTS
I changed my fuel filter and now when i hit the gas at 40 it chokes
May 16, 2010 at 3:18 PM
INTERNETMECHANIC
  • 700 POSTS
Use a gage and check fuel pressure. Some of the national brand autostores used to loan out a fuel pressure gage, if you don't have one. If your fully obd1 compliant, check for any applicable mil codes. Sometimes the fuel poppets need cleaning. Right now I suspect a fuel issue, could be something other.
May 17, 2010 at 3:53 AM
WESLEY_MYS
  • 10 POSTS
what and where are fuel poppets
May 17, 2010 at 4:19 AM
INTERNETMECHANIC
  • 700 POSTS
If you have the spider fuel system, you have to remove the upper manifold to get at them. The best cleaning procedure is a shop procedure. I don't know if injector cleaner in the gas tank will help?
May 18, 2010 at 3:18 AM
