Hello eveyone. Well I now have a 95 astro van. Problem, 2 saturdays ago I drove the van all day and it started ran and drove just fine. I got up the following morning and it would not start. I let it sit for a few moments and then it started and ran fine just as it did the day before. The following weekend again I drove all day sunday with no problems, Monday it would not start. 3 days later I tried it again it started and I drove it all night no problems. Well next day no start again this time it wouldl not start at all, and has been this way since.
sensors I have changed map, control module, change coil pack, checked spark plugs but did not change wires, changed distributor cap and rotor, fuel pump with both filter and screen checked fuel pump relay and fuses, pourd shot of gas into throttle, checked ground wires. I have fuel to rail and spark at distributer, timing belt appears to be intact. Non of this has got the van running. I have ran out of options. I don't own a fuel pressure tester or voltmeter, so I have not checked specifications, but I have checked for codes and only code 12 appears.
It just sounds as if its not getting spark or fuel as I crank the motor but I can't figure out whats wrong.
any help would be awsome.
Richard
Richard
Jan 11, 2009 at 8:44 AM
