1995 Chevy Astro Loose Steering
288,000 MILES • 6 CYL • AWD • AUTOMATIC
MADMANEX
The steering feels very loose in general. When I say loose steering I mean that sometimes the van changes direction without me moving the steering wheel and sometimes I have to move the steering wheel quite a ways before the van actually turns.
When I am traveling at highway speeds and I hit a dip in the road, the van will sometimes veer to the left. Anytime I hit a dip in the road at highway speeds, the steering feels loose.
I had all the shocks replaced recently and the response to dips in the road seems better but the steering is still very loose. My regular mechanic is at a loss to determine the exact cause and can only suggest that I replace nearly everything on the front end. Is there a way to determine exactly which part or parts is in need of replacement? What is the best way to repair this problem?
Jun 21, 2009 at 8:09 AM
BUDDYCRAIGG
  • 2,262 POSTS
I find it difficult to believe that EVERYTHING needs to be replaced.
you said your "regular mechanic" which suggests you will not be doing the work yourself.
take it to a different shop for a second opinion.
Jun 21, 2009 at 10:24 AM
