1995 Chevy Astro Headlights
1995 CHEVROLET ASTRO
14,900 MILES • 6 CYL • 2WD • AUTOMATIC
HERBDOG
Why won't my headlighs work? Every light works except for the headlights. My highbeams won't go on either. Is there a fuse?
Apr 1, 2010 at 5:45 AM
TWOSTEPPER
  • 42 POSTS
I'd have to check voltage circuits to and from the headlamp switch. There is no fuse for the headlamp section, there is a circuit breaker in the headlamp switch, also a fusible link on the circuit that carries voltage to the switch. Red wire should be feed for headlamp, then, yellow wire carries headlamp feed to dimmer switch. From dimmer switch to headlamps. Without checking the wiring circuits, can't be sure where the problem is located.
Apr 1, 2010 at 7:40 AM
HERBDOG
WOW!!!! Thank You very much...this is an awesome website
Apr 1, 2010 at 8:11 AM
