1995 Chevy Astro gas problem
10,900 MILES • 6 CYL • 2WD • AUTOMATIC
JULEGOLD58
if you puyt gas in carb it will run but when you try to push on the gas it dies and will not start unless you put more gas directly into carb. but the fuel pump is working and the fuel filter is new. please tell other issues that may cause this to happen
Oct 27, 2008 at 3:27 PM
JDL
  • 16,098 POSTS
If you have the cmfi fuel system, there are bulletins about cleaning the fuel poppets.
I know you said the pump runs, but, I can't rule out a fuel pressure issue. Can you check fuel pressure? It does sound like a fuel issue.
If your still obd 1, 12 pin data link connector, check for codes.
Oct 28, 2008 at 3:05 AM
