1995 Chevy Astro fuel pump
DON30ALD
  • 1995 CHEVROLET ASTRO
1995 Chevy Astro 6 cyl All Wheel Drive Automatic
vehicle wont turn over I beleive it might be the fuel relay or the fuel pump any advice. And where is the pump located on this vehicle
thanks
Monday, April 20th, 2009 AT 12:24 PM
BLUELIGHTNIN6
  • 16,542 POSTS
If you have checked spark already then you need to check fuel pressure at rail. Inspect fuel pump relay located on bracket, on right rear of engine compartment. Fuel pump is located inside fuel tank.
Thanks for using 2CarPros. Com!
Monday, April 20th, 2009 AT 12:51 PM
