Firing order?
1995 CHEVROLET ASTRO
RDCD1234
The van is backfiring I was wondering if I have a crossed plug wire.  I replaced the plugs and wires also. Thanks For the help
Jun 20, 2008 at 2:14 PM
  • 55,224 POSTS
Yes, this can be the problem, here I have included some firing order diagrams so you can double check. Please let me know if you need anything else.
https://images.2carpros.com/forum/automotive_pictures/12900_f1_7.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_f2_6.jpg
Best, Ken
Jan 17, 2017 at 4:46 AM
JSNAPZ1212
what is the Firing order for 1995 chevy astro 4.3L
Jun 29, 2020 at 4:33 AM (Merged)
SERVICE WRITER
  • 9,123 POSTS
1-6-5-4-3-2
LEILANI67
DONT HAVE THE TROUBLESHOOTING SECTION IN MY MANUAL. COULD I PLEASE HAVE THE FIRING ORDER OF SPARK PLUGS FOR CHEVY ASTRO.THANK YOU!
JDL
  • 16,098 POSTS
What is the litre size of engine?
JDL
  • 16,098 POSTS
This info is for the 4.3L engine.
WESLEY_MYS
  • 10 POSTS
my distributor is 380 out. best way to reset it
Do you have a repair manual if so-Put the engine no.1 piston on its compression stroke/TDC, align the cam and crank sprockets to their markings, put crank pulley on TDC/0 deg and rotor pointing to no.1 cap tower.
GENTECHIT
When the plug wires are coming from the distributor cap to the Spark Plugs, Which wire goes to which plug?
  • 110,240 POSTS
Here is a picture of what you need.
https://images.2carpros.com/forum/automotive_pictures/249084_firing_order_4.jpg
Let me know if it helps. Joe
ANDYS
the order on a distrubeter cap. 1992 astro cahevy 2 w/d
DOCFIXIT
  • 18,828 POSTS
this help
ANDYS
the cap does not have any numbers so i dont know which is one
ANDYS
it turns on but i feel like i have to put more force on the gas. it feels more heavy to ride
DOCFIXIT
  • 18,828 POSTS
How many miles on plugs,filters wires cap ect. has fuel pressure been checked. Check engine light on? this sudden or came on over time?
ERNIE SWAN
I was hoping to find out the wiring order of the spark plug wires at the Distributor cap?
Jun 29, 2020 at 4:34 AM (Merged)
OBXAUTOMEDIC
  • 3,711 POSTS
Hello, Here is the firing order....
https://images.2carpros.com/forum/automotive_pictures/188069_90astrofiringorder_1.jpg
ERIKATVEGAS
what is the firing order on the distributor cap?
Specifications FIRING ORDER
https://images.2carpros.com/forum/automotive_pictures/12900_fo_139.jpg
