1995 Chevy Astro filters
165,000 MILES • 6 CYL • 2WD • AUTOMATIC
WESLEY_MYS
  • 10 POSTS
is there a filter on my carburetor and location
May 11, 2010 at 1:58 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The fuel filter should be under the vehicle, driver side, below seating area, front of fuel tank, mounted on chassis in fuel line
May 11, 2010 at 2:23 PM
WESLEY_MYS
  • 10 POSTS
is that the only filter for fuel
May 11, 2010 at 3:59 PM
BLUELIGHTNIN6
  • 16,542 POSTS
yes, what is the problem you are having?
May 11, 2010 at 4:03 PM
WESLEY_MYS
  • 10 POSTS
my van is sputtering. like a filter is clogged up. like water is in my tank
May 11, 2010 at 4:48 PM
BLUELIGHTNIN6
  • 16,542 POSTS
have you already replaced said filter? also try fuel treatment with the next fill up. also check the spark plugs, it could be a spark issue
May 11, 2010 at 4:50 PM
