1995 Chevy Astro doesn't start
RICHINMD
  • 1995 CHEVROLET ASTRO
  • 6 CYL
  • 145,000 MILES
1995 Astro 6 cylinder VIN W. Vehicle was running fine until it started going uphill then it lost power and died completely. Fuel pump was changed 2 months ago. Just changed the fuel filter and ignition module in the distributor. New cap and rotor as well. Shot some engine starter down the intake and van started for a couple of seconds and then died. Performed fuel pressure test. Initially key on and engine off: 22 psi. Momentarily key off then key on 32-36 psi. Engine cranking 36-38 psi. Immediately after cranking, you can hear the pump running, tops out at 38 psi until pump kicks off and drops to zero. Fuel pressure always dropped back to zero almost immediately at the completion of each fuel pressure test. I suspect a bad fuel pressure regulator. Is there anything that I am missing? If not, how difficult is it to replace the fuel injection unit or should I just get it towed to a dealer and let them fix it?
Thanks in advance,
Rich
Tuesday, May 19th, 2009 AT 10:35 AM
RICHINMD
I disconnected the fuel filter and took a direct reading from the tank to where the filter was. I came up with 30 psi so that tells me that the check valve in the pump must be the culprit.
New pump on order, will update after I change it.
Saturday, May 23rd, 2009 AT 11:17 PM
RICHINMD
New pump installed, all pressures are good. Bleed down pressure is a little fast so a new pressure regulator will be the next thing to fix.
Vehicle started on the first try!
Sunday, May 31st, 2009 AT 1:21 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Hi Rich,
Sorry we missed your question.
Sounds like you've done a Great Job of diagnosis on your own.
Fantastic Work
Sunday, May 31st, 2009 AT 2:20 PM
