1995 Chevy Astro Daytime Running/Backup Lights
JHAYNES2
Electrical problem
1995 Chevy Astro 6 cyl Two Wheel Drive Automatic
First of all my daytime running lights do not work at all, the fuse looks good, and the headlight assembly recently replaced (did not work previous to replacement).
Second, back up lights do not always work, e.g. I can be backing into my driveway and they do not work, I may hit a bump and they suddenly work.
Any ideas?
May 18, 2008 at 3:32 PM
TECHMAN1
  • 82 POSTS
[quote:a1b05c60b7="jhaynes2"]Electrical problem
Any ideas?[/quote:a1b05c60b7]
Rusty ground wires. Find every ground wire you can, remove it, sand it, wet and the surface where bolts to with motor oil.
May 23, 2008 at 3:33 PM
