1995 Chevy Astro dash and tail lights
162,000 MILES • 6 CYL • AWD • AUTOMATIC
TURBO2663
when i turn on my headlights my headligths, tail lights and dash lights come on, but only for a min. the horn fuse blows and i loose my dash and tail lights. i already replaced the switch. can u point me in another direction.
May 15, 2008 at 11:47 PM
MASTERTECHTIM
  • 4,750 POSTS
there is a short in the brown wire to the running lights. you must find where the wire is rubbing ground, most likely causes are near the marker lights them selves, look where the bulb sockets are and look to see if you can see some bare wire. its process of elimination, you must find the shorted wire, also look under the drivers carpet area this is where the harness goes to the rear of truck, also check for a shorted trailer light harness.
May 15, 2008 at 11:50 PM
