1994 Chevy Astro won't idle
175,867 MILES • 6 CYL • 2WD • AUTOMATIC
CRSSR1977
The van started out sputtering when i had to give it gas to take off then started having idle issues and now it wont start i have changed the fuel pump, filter, idle air valve positional relay, computer and did a comeplete tune up but still can't get it to run any ideals. i can't aford a shop so i saw u guys and hope u can help
thank you
chris
Jul 23, 2010 at 8:45 AM
JDL
  • 16,098 POSTS
Any applicable trouble codes? Engine cranking, do you have spark at the plugs, check visually. Use a gage and check fuel pressure. Some of the national brand autostores used to loan out a fuel pressure gage.
Jul 23, 2010 at 9:06 AM
CRSSR1977
i got my 94 astro running again but the ideling is surging it all but shuts down when it gives a shot of gas then idels right for a few seconds and then starts all over again
Jul 31, 2010 at 6:09 AM
