1994 Chevy Astro van surges while idling and when it is put
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
HARRYBOONE
I have just replaced the fuel pressure regulator, now the van will crank, but it will not idle correctly or cranks and then immediately staalls, and when i put the van in DRIVE, the engine surges and eventually stalls. Also replaced vaccum lines today, and spider relay 2.5years ago.
Oct 6, 2010 at 3:26 AM
  • 75,988 POSTS
Clean out the idle air control valve and test the throttle position and manifold absolute pressure sensors to include a fuel pressure check
Oct 6, 2010 at 5:41 AM
