1994 Chevy Astro Replacement rear axle , passenger side
10,000 MILES • 6 CYL • 2WD • AUTOMATIC
GREGG_4
I have been experiencing difficulty locating an axle to replace mine. I have tore out 3 axles from Astro Vans and axles are not the same. These axles don't fit because the gears are smaller on mine and the ones i pulled are larger. Have you got any suggestions or reason why i am experiencing this difficulty
Mar 2, 2008 at 4:16 AM
REPAIR ME
[quote:70d190abf3="gregg_4"]Drive Train Axles Bearings problem
1994 Chevy Astro 6 cyl Two Wheel Drive Automatic 100,00 miles
I have been experiencing difficulty locating an axle to replace mine. I have tore out 3 axles from Astro Vans and axles are not the same. These axles don't fit because the gears are smaller on mine and the ones i pulled are larger. Have you got any suggestions or reason why i am experiencing this difficulty[/quote:70d190abf3]
Have you pulled a right for your Astro?
Apr 4, 2008 at 1:54 PM
