We have changed the fuel pump and filter, we have power, but no power to the fuel pump, can you tell us where the relay or fuse is?
Dec 20, 2007 at 10:13 AM
DENNYP
✓Experienced Mechanic
I think the fuel pump relay is located on the firewall above the evaporator case. It will be on the passenger side of the vehicle.
Dec 21, 2007 at 11:48 AM
CHUBBER22
MEMBER
I have changed four fuel pumps on my 96 you have to also check the ECM fuse in the panel under the hood driver's side for the 96. I'm not sure where it is located on the 94 check both fuse boxes one under the dash drivers side the other under the hood drive's side.
