1994 Chevy Astro fluid
DCHECK2V
Transmission problem
1994 Chevy Astro 6 cyl Four Wheel Drive Automatic
when getting full service and transmission line replaced, should a mechanic be responsible of refilling the transmission, and how much fluid does transmission hold?
Jan 2, 2010 at 12:09 PM
JAYBIN82
  • 44 POSTS
YES they should be responsible! filling the transmission back up is part of the job. depends on the transmission, mine holds about 5 qt. you can call your local aout parts store they should be able to tell you
Jan 2, 2010 at 12:33 PM
