1994 Chevy Astro door handle
150,000 MILES • 6 CYL • AWD • AUTOMATIC
42BLACKIE
door handle broken cannot open door inside or outside, how does one get door open to replace handle. replaced passenger side already but the door open from inside. this one will not open at all
Apr 7, 2009 at 2:29 AM
LYMETYME
You will have to remove the door panel, (handle/armrest)window crank (if manual) disconnect rods going to lock and inner handle. Then the fun begins. You will need a good light, a long screw driver or similar, and helpful to have a small mirror. ( seven jointed arms wouldnt hurt either).
Now look for the inner piece of your door handle (the one you use when you are on the outside of the vehicle.
Make sure first that the door is UN locked. You will see, attached to the door handle a short rod, with a slight bend attached to this handle, it may be difficult to see, as it will be between the outer door skin and the window track. Pulll this rod down.
This will open the door. If you are having difficulty doing so, it is likely that the door handle as it broke, stuck between open and closed. Knock it around a bit with a sturdy rod, to free it up. This may allow you to open the door, just by pulling on the inner door handle rod.
Apr 21, 2009 at 3:15 PM
