1994 Chevy Astro Cruise Control
190,000 MILES • 6 CYL • 2WD • AUTOMATIC
TS2109
Good Morning,
Very often the cruise control disengages on it's own. Once this happens if you simply push "resume" on the controller it will not activate. If you tap the brake then hit "resume" it activates again properly till the next time it disengages on its own.
Anything I can check, possibly an air leak somewhere or would it be an electrical issue?
Thanks, Tommy
Oct 16, 2009 at 12:49 AM
SATURNTECH9
  • 30,869 POSTS
u mentioned if u tap the brake it works again i think the problem is the brake switch or the adjustment of the brake switch when u step on the brake the cruise control cancels so if the switch is going on without stepping on the brake ur cruise would shut off start there i think thats ur best bet from what u have told me.let me know how it goes.
louie
Oct 16, 2009 at 6:59 AM
