1994 Chevy Astro codes
15,300 MILES • 6 CYL • 2WD • AUTOMATIC
CLEATUS72
i have a 94 astro van i had it in the shop and he said it had 2 codes i am trying to find out what they are and how hard it is to fix them the first is 43 the second is 44 thank you
Sep 6, 2009 at 7:23 AM
  • 75,988 POSTS
Diagnostic Trouble Codes - 1994
Chevrolet
13 Open Oxygen Sensor Circuit
14 Coolant Temperature Sensor (High Temp Indicated)
15 Coolant Temperature Sensor (Low Temp Indicated)
21 Throttle Position Sensor (Signal Voltage High)
22 Throttle Position Sensor (Signal Voltage Low)
23 Manifold Air Temperature (MAT) Low Temp Indicated
24 Vehicle Speed Sensor (VSS) Circuit
25 Manifold Air Temperature (MAT) High Temp Indicated
32 Exhaust Gas Recirculation (EGR) Circuit
33 Manifold Absolute Pressure Sensor Circuit (High Sig.)
34 Manifold Absolute Pressure Sensor Circuit (Low Sig.)
35 Idle Air Control (IAC)
41 Cylinder Select Error
42 Ignition Control (IC) Circuit
43 Knock Sensor (KS) Circuit
44 Oxygen Sensor Circuit (Lean Exhaust Indicated)
45 Oxygen Sensor Circuit (Rich Exhaust Indicated)
51 EEPROM or ECM Failure
53 System Voltage Overcharge
54 Fuel Pump Circuit (Low Voltage)
55 ECM Error
61 Degraded Oxygen Sensor
62 Transaxle Gear Switch Signal Circuit
63 A/C Refrigerant Pressure Sensor Circuit
Sep 6, 2009 at 7:50 AM
