1994 Chevy Astro car stalls at stops
1994 CHEVROLET ASTRO
153,000 MILES • 6 CYL • AWD • AUTOMATIC
YOOPER73
My problem started after I filled with gas. It started idling quite rough and sometimes ran sluggish. Now it runs good but stalls at stops and wont idle. It will start. I suspected dirty gas. I put injector cleaner in and stuff to absorb water. It hasn't cured the problem. The stalling just started last night
Feb 14, 2009 at 7:15 AM
MERLIN2021
  • CAR REPAIR CONTRIBUTOR
  • 17,250 POSTS
Check the fuel pressure, if you run the van to near empty then refuel, you may have overheated the pump, fill up at 1/4 tank so you dont fry the pump. If pressure is OK Clean the throttlebody and check or replace the IAC, Idle air control, it's bolted to the TBI.
https://images.2carpros.com/forum/automotive_pictures/62217_CRC_Throttle_Body_11.jpg
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm Go here and checkout our video.
Feb 14, 2009 at 7:22 AM
