1994 Chevy Astro Astro van cut's out and dies.
FREEDLUND
  • 1994 CHEVROLET ASTRO
Engine Mechanical problem
1994 Chevy Astro 6 cyl Two Wheel Drive 200, 00 miles
My Astro van cut's out and dies. Fuel pressure good, compression is good, new tune up, 02 sensors good, injectors spray. What could it be?
Wednesday, January 27th, 2010 AT 4:20 PM
You got good fuel pressure did you confirm this with a fuel pressure gauge if so what was the pressure readings. Also did you check for an ignition spark-No spark equals to No Start
Wednesday, January 27th, 2010 AT 4:51 PM
FREEDLUND
It's always had good spark & the fuel pressure is 45#'s with a gauge. After shutting engine down with the key on the pressure drop's to "0" within 10 minutes. It doesn't accelerate up to speed when driving.
Thank you!
Steve
Thursday, January 28th, 2010 AT 10:18 PM
Your fuel pressure should be 55-61psi and the fuel pressure shouldn't drop the fast to zero
Friday, January 29th, 2010 AT 11:20 AM
