1994 Chevy Astro
MARIEFO52
Engine Mechanical problem
1994 Chevy Astro 6 cyl Two Wheel Drive Automatic
WILL START WHEN COLD CAN DRIVE SOMEWHERE WILL NOT STARTTO RETURE HOME . TRIED SPRAY IN INTAKE WILL START ,CUT OFF SPARY AGAIN START CUT OFF . GO BAKE 2 DAYS LATER STARTS ON OWN. IF IT SITS IN YARD WILL START EVERY TIME.CAN IT BE FULD PUMP GETS HOT CHANGE IT?
Aug 9, 2009 at 7:05 AM
  • 110,251 POSTS
If it starts with starting fluid, it is fuel related. Before replacing the fuel pump, make sure there isn't a problem with the regulator. Check fuel pump pressure when it doesn't start so you know what is happening.
Here is a how to for checking the pressure.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
Sep 3, 2009 at 12:51 AM
