1994 Chevy Astro
BILL BONNET
Engine Mechanical problem
1994 Chevy Astro 6 cyl Two Wheel Drive Automatic
I HAVE A 94 ASTRO THATS HARD TO START.I REPLACED FUEL INJECTION ASSEMBLY,DISTBUTOR,ROTOR,PLUGS GET 60PSI FUEL PRESSURE.RUNS AND DRIVES FINE WHEN STARTED.
Mar 17, 2009 at 11:02 AM
JDL
  • 16,098 POSTS
Hello, that fuel pressure you listed, is that key on engine off?
Mar 20, 2009 at 1:19 AM
BILL BONNET
thats with the key on is 60psi fuel pressure,smell gas like it's flooding when it won't start,does the same after it runs and shut off and i try to restarted it smells like it's flooded.
Mar 20, 2009 at 12:34 PM
JDL
  • 16,098 POSTS
Does the pressure leak down after you turn the key off?
That is a new spider assembly? You shouldn't smell gas unless there is a leak, somewhere.
Mar 21, 2009 at 2:33 AM
