1994 Chevy Astro
STEVENF
Electrical problem
1994 Chevy Astro 6 cyl All Wheel Drive Automatic
NO POWER TO FUEL PUMP. CHECKED FUSE, GROUNDS, REPLACED RELAY,PUMP,AND SENDING UNIT. ARE OTHER FUSES OR BREAKERS?
Mar 14, 2009 at 2:00 AM
JDL
  • 16,098 POSTS
Did you check the ecmB fuse, also check for voltage where the fuse plugs in, should be hot all the time. What's the vin for the engine?
Mar 16, 2009 at 1:24 AM
