1993 Chevy Astro stalling
178,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAVID BROWN
Engine is a 4.3 CMFI . When idling runs rough and if I remove the plug wires on the 3 cylinders on drivers side it doesnt make a difference in idle speed.Spark is good,so is compression and fuel pressure.
Feb 3, 2008 at 11:24 PM
BLACKOP555
  • 10,386 POSTS
check to see if each of your poppet valves from your spider is spraying out fuel and of good quantity.
Mar 21, 2008 at 6:02 AM
