I have 1993 Chevy Astro van that will not start it seems to crank very good. What should I do next
Mar 13, 2010 at 12:09 AM
✓Experienced Mechanic
Are you getting spark and fuel to the engine?
IF you need directions on how to check, let me know.
Mar 13, 2010 at 4:01 AM
CADDY47
MEMBER
yes I am getting spark but no fuel. I have install a new fuel pump still no fuel pump. I have the air cleaner off and there is no fuel smell or nothing. What should I do next?
Jun 1, 2010 at 8:42 AM
When you had the pump out, did you check to see if there was power to it? Also, have you checked the fuel pump relay?
