I have 93 astro van after checking fuses under dash I replaced the fuel pump because it was not running with key on. It still did not run then I tested old pump on battery and it worked. so I figured good fuses good pump must be power problem , I hot wired pump then the van started and ran with out hot wire to pump. I figured it had to be computer and replaced it. It did not help. I started looking more and checked 5 fuse links behind battery they are all good. I figured what the heck and tried to read computer. and notice they are no check engine light burning. I am now stumped. please help
Apr 13, 2009 at 7:07 AM
