1993 Chevy Astro emergency brake light on dash staying on
SOFA747
Brakes problem
1993 Chevy Astro 6 cyl Two Wheel Drive Automatic
i just changed brakes all the way around on my van. on the front i replaced pads and rotors, on the back pads and drum hardware kit were installed. now my emergency brake light is staying on. what would be causing this? my 60 year old mother drives my can and i would rather here be safe then have a problem on the road.
Sep 28, 2009 at 5:54 AM
  • 110,248 POSTS
Is the brake fluid full? Is the park brake pedal fully returning?
Sep 28, 2009 at 1:11 PM
SOFA747
yes to both questions that is why i am completely stumped on it
Sep 28, 2009 at 1:24 PM
  • 110,248 POSTS
When you depressed the caliper pistons, did you force the brake fluid back into the master cylender or bleed it out at the caliper bleeder? If you forced it through the master cylender, you may have damaged it.
Sep 28, 2009 at 2:03 PM
SOFA747
i bled it out at the bleeder. i have rechecked and readjusted the back brakes to make sure everything was in the right position and i have rechecked the seating of the pads at the front and the ebrake light is still on.
Sep 28, 2009 at 10:52 PM
  • 110,248 POSTS
The only other thing I can say about the park brake is to make sure the switch is properly adjusted and is working. It is located under the dash near the e-brake pedal. It will be mounted in the assembly near the top.
Sep 29, 2009 at 12:57 AM
  • 110,248 POSTS
Check the switch to make sure it is working properly. Disconnect the plug and jump it to see if the light goes out.
Sep 29, 2009 at 1:59 AM
