1993 Chevy Astro Automatic Door Locks
1993 CHEVROLET ASTRO
14,400 MILES • 6 CYL • 2WD • AUTOMATIC
TOMMCL612
My passenger side door lock switch broke and started shorting out so I took the 30 amp circuit breaker out for several months. I went to an auto salvage and replaced the switch but now nothing works. It's totally dead and none of the doors make any sound to show me I have a complete circuit.
Thanks.
Sep 4, 2010 at 5:42 AM
WILLIAM_STELTER
  • 24 POSTS
Double check fuse. Double check all wires are inserted correctly. If fuse didnt blow then it is a wiring problem. Probally not in youd door. You would have to find where the problem is. Not a fun thing to do. I would start with the driver door. Dis connect all switches besides that switch and see if it works.
Sep 22, 2010 at 8:08 AM
