I have replaced O2 sensor, PCV, EGR, map, ignition control module, fuel pump, fuel filter, temp sensor, and many other things. No vacuum leaks. Fuel pressure OK.
When I first start the engine cold it will run perfectly for 5-10 seconds when the outside temp is fairly warm. In the winter, it will run great for 10-30 seconds. If I shut it off and turn back on it will run perfectly for 5-10 seconds again. I think it has to do witha bad sensor or something.
Heres another thing. When I remove the gas cap for a fill up or any other reason and then replace it, it will run even worse. Eventually it will run better until the gas cap is removed.
Help
SPONSORED LINKS
Saturday, December 22nd, 2007 AT 9:53 PM
